willaduncan Posted May 13, 2015 Report Posted May 13, 2015 I got plastics if g falls out Sent from my iPhone using Tapatalk Quote
98_sheester Posted May 13, 2015 Report Posted May 13, 2015 Good luck fellas unless the motor is sold hes keeping it whole Quote
gordo_dk Posted May 13, 2015 Author Report Posted May 13, 2015 Yes guys sorry but if it does sell g you got dibs on plastics then willaduncan Sent from my iPhone using Tapatalk 1 Quote
hp2000 Posted May 13, 2015 Report Posted May 13, 2015 Got any close up pics of the motor? Sent from my iPhone using Tapatalk Quote
Banshee SE Posted May 13, 2015 Report Posted May 13, 2015 (edited) Where are you located? Like hp said do you have close up pictures of the motor? Also could you give more details on motor, transmission,clutch set up, compression,etc.? Sent from my iPad using Tapatalk Edited May 13, 2015 by Banshee SE Quote
gordo_dk Posted May 13, 2015 Author Report Posted May 13, 2015 I'll see if I can get pics of the motor, since the bike is at a buddy's house....motor is a Tripones built 421 cub with pro mod transmission, driveline clutch, direct drive lock up, chariot head, 68mm bore wiseco pistons, hot rods 115mm rod crank trued and welded by Jeff at fast, 19cc domes with +8 timing. Chariot stator cover Sent from my iPhone using Tapatalk 2 Quote
gordo_dk Posted May 13, 2015 Author Report Posted May 13, 2015 Located in Brawley, ca Sent from my iPhone using Tapatalk Quote
gordo_dk Posted May 14, 2015 Author Report Posted May 14, 2015 Sent from my iPhone using Tapatalk Quote
gordo_dk Posted May 14, 2015 Author Report Posted May 14, 2015 R Sent from my iPhone using Tapatalk Quote
BrokeVW Posted May 14, 2015 Report Posted May 14, 2015 How much does the motor weigh, and what ZIP code is it in (92227)? I would have to have it shipped to Ohio, can you crate it to securely make the trip via UPS Ground? Is there anything wrong with it? Any leaks? (carbs, casing, etc.) When was it built? Any casing damage inside or from chain? Engine, reeds, carbs, and pipes for $1500? I'm a serious buyer with money in hand, if we can strike a deal... email me at [email protected] to discuss specifics. Brian Quote
gordo_dk Posted May 14, 2015 Author Report Posted May 14, 2015 Please read post, asking 2k complete, motor was built last year but only has about 2 hours run time, 1500 for motor alone, no leaks as far as I know Sent from my iPhone using Tapatalk Quote
gordo_dk Posted May 16, 2015 Author Report Posted May 16, 2015 Last bump before I decide to keep Sent from my iPhone using Tapatalk Quote
