llawnmeister Posted April 20, 2015 Report Posted April 20, 2015 Do the leak down test, if good then measure your cylinder too see if it is within spec for the piston installed, if so, lightly hone cylinder so new rings will seat properly. Do both cylinders even though only one is low! I have been told on a re ring that only two heat cycles are needed to seat rings before you give it all it's got! Others can verify or modify that if needed. Quote
