Took my 2000 banshee to pismo beach in California on Saturday. I feel like I had to Rev it real high in first else it was bogging,lost power and Stalled. Also the power would kick in all of a sudden.Same goes for the other gears. It was my first time actually riding it. Also it spit a little bit of engine ice antifreeze a couple times during the day and it was about 75 degree out. Any ideas would help.thankx.
-2000 yamaha Banshee
-32:1 mix ratio
-fmf gnarly pipes,fmf core 2 silencers
-310 & 27.5 jets
-stock carbs with tors removal kit
-carbs are synced
- air mix screw 1 & 1/2 turns out
- stock needles on 3rd notch
- dual air filter pods
I bet you have an airleak causing you to run lean.
Leakdown test the motor before you grenade it.
BTW, FMF's call for 30 pilots.
Your needle clip position and main jet is perfect.
