hi there pulled head and bores off my banshee today just to check how the athena bore kit was going and i need put a new base gasket in cause the old one got damaged when pulling off
my  question is will a standard base gasket be alright to put on with the athena bores or do u have to get a athena gasket they look the same just not sure thanks guys
Measure the old gasket with a venir caliper and get a gasket close to the original. U should have measured the squish before u took it apart this way when you reassemble you know the number your shooting for. Prob a .020 base gasket will suffice
