ninjamaster Posted November 24, 2003 Report Posted November 24, 2003 I dont drive fast but I acclerate extremly hard most of the time. I drive in 2nd over the bumps and third on the straight aways. Will I hurt my quad if I rev it to the max as in keeping it in 2nd gear high rev as oposed to 3rd gear low to moderate and 3rd gear high instead of 4th moderate? Keep in mind it id a stock 01. Should I run my mix with 5 oz instead of 4 to prevent damage? thanks and by the way this is an awsome site. Quote
BlewBullet Posted November 25, 2003 Report Posted November 25, 2003 I personally wouldn't do it...even though I;ve watched my friend time and time again do it while doing breakstands for a couple thousand feet...it's good to clean her out and hold it but the way you're supposed to ride it is to the stopper and off off and on if im doing a hill climb i will hold it but rather then that not for just all around riding..theres no rev limiter like a 4 stroke so..maybe ur best bet would be to buy one.. Quote
Blue Duece Posted November 25, 2003 Report Posted November 25, 2003 I dont drive fast but I acclerate extremly hard most of the time. I drive in 2nd over the bumps and third on the straight aways. Will I hurt my quad if I rev it to the max as in keeping it in 2nd gear high rev as oposed to 3rd gear low to moderate and 3rd gear high instead of 4th moderate? Keep in mind it id a stock 01. Should I run my mix with 5 oz instead of 4 to prevent damage? thanks and by the way this is an awsome site. id hold it wide open pinned after i stuck a 15 tooth sprocket up front, it will float less, and chances are if your in the dirt you'll be letting off long before youd blow her up Quote
