Yamo Posted February 7, 2015 Report Posted February 7, 2015 I just took off the carbs the first time since i bought my banshee and I just wanted to clean them out and see what was causing a small leak so took the float bowl off and the float needle just to see how clean they were and i put everything back together i made sure the needle jet went into the main jet hole and i made sure everything was sealed properly and when i went to start it back up it sounded different and a lot more smoke came out and it wont idle unless i give it some gas. before i took the carbs out it idled fine and would stay on idle. anybody know what it could be? I would appreciate any insight thanks. Quote
sheerider11 Posted February 7, 2015 Report Posted February 7, 2015 Carb slides swapped? Choke tube? Bowls swapped? Quote
Yamo Posted February 7, 2015 Author Report Posted February 7, 2015 this is pry a stupid question but how do i tell if they are swapped? Quote
Yamo Posted February 7, 2015 Author Report Posted February 7, 2015 i had a choke tube i found that it was my carb slides were swapped thanks for your knowledge guys! Quote
nickolasengland Posted February 8, 2015 Report Posted February 8, 2015 My banshee is sputtering on high end, it's jetted appropriately and cleaned carbs and changed plugs, could it be a ecu or stator problem? Quote
Larry's Shee Posted February 8, 2015 Report Posted February 8, 2015 My banshee is sputtering on high end, it's jetted appropriately and cleaned carbs and changed plugs, could it be a ecu or stator problem? WELCOME !! Starting your own thread might work better than jacking this one. How do you know it's jetted right? We'll need more info to help. A list of all modifications that you know of. Main and pilot jet sizes. Elevation and temps you ride at. FYI, Banshees have a CDI not ECU. Quote
nickolasengland Posted February 8, 2015 Report Posted February 8, 2015 Sorry, I can't figure out this thread app. Wasn't sure on how to start my own thread Quote
