ryan954 Posted January 22, 2015 Report Posted January 22, 2015 Currently rebuilding my banshee. Once i put her back together i dont want to have to open here up again. So im going to list everything i have and can you guys let me know if im missing anything. Ive been doing alot of reading and research and i think i have everything. This form is fucking great. Im doing a 4mil several build from jeff over at fast Bottom end Hotrod crank trued and welded(jeff is putting an extra weld on it) Will be using maxload bearings Promod transmission from redline racing With new shift forks Modded shift star, modded shift shaft ez shift spring,shift shaft torsion spring, pancake bearing, new clutch rod and ball,and new eccentric stud Hinson clutch basket, new stock inner hub, racing clutch kit from fast and driveline performance lock up new flywheel from fast, new stator from gary with new advanced timing plate and pick up coil All new seals and bearings Will have cases sandblasted and painted Topend Noss coolhead from fast with 21cc domes 4mil several cylinders and pistons from fast vforce 4 reeds 35 pwks Billet one piece intake oversized radiator, billet water pump with new bearing, new hoses Ignition Nology coil and wires Dynatek cdi New wiring harness All new hoses cables and fluids. did i miss anything? Quote
ryan954 Posted January 22, 2015 Author Report Posted January 22, 2015 I have the lock up already and it fits under the stock cover. And i am ss bolts. I found a kit on ebay Quote
Hummer84 Posted January 22, 2015 Report Posted January 22, 2015 say wut? fits under the stock cover you say? hmm......whats the need for a lockup? I have the same motor ported no lockup.....I was told there was really no need for it. Quote
ryan954 Posted January 22, 2015 Author Report Posted January 22, 2015 Yes it has little balls in it.Its made by driveline preformance. And it was already on there when i bought the bike Quote
ryan954 Posted January 22, 2015 Author Report Posted January 22, 2015 And yes it fits under a stock cover. Jus had to grind it a little. But it fits. Quote
ryan954 Posted January 22, 2015 Author Report Posted January 22, 2015 Hey zillafreak my shift cam dnt have a bearing. Quote
Atomic Monkey Posted January 22, 2015 Report Posted January 22, 2015 Isn't the bearing part of the "Promod"? Quote
sprinklerman Posted January 22, 2015 Report Posted January 22, 2015 Isn't the bearing part of the "Promod"?Some do it,some don't. Results are inconclusive to me. I've had both,couldn't tell a difference. Quote
Atomic Monkey Posted January 22, 2015 Report Posted January 22, 2015 I see, mine came back with the bearing on the drum so I was curious. And yeah Sprinklerman, when I assembled everything there was no real wear in the case from the way it was stock. What I did notice was where the shift shaft comes through the clutch side case, that looks like a good spot for a bearing or bushing as my case was a little egged out, and there was some galling on the original shift shaft. I didn't do anything about it, but is there a "mod" for that? Quote
dirtydownunder Posted January 22, 2015 Report Posted January 22, 2015 dont use the ez spring from the kit, just use the arm with bearing and stock spring, or the slightly softer aftermarket spring. dont use dynatech cdi, just run stock cdi with a timing plate. i dont run the bearing with pro mod and its fine, but cant hurt to have one. id get the serval ported, stock port servals are lazy as. stock port serval, does not need a lock up, but if youre going to trail ride it, you can use stock clutch pressure plate spring and a lock up so the clutch isnt too stiff. and id wet bead blast the cases instead of sand blast. and powder coat the cylinders as paint would just chip off, ultimately i wouldnt coat or paint them. bare looks better id also port match the cases to the cylinders. Quote
ryan954 Posted January 22, 2015 Author Report Posted January 22, 2015 What kind of port job should i have done to the cylinders. Ill be doin more racing than trail riding Quote
ryan954 Posted January 22, 2015 Author Report Posted January 22, 2015 What kind of port job should i have done to the cylinders. Ill be doin more racing than trail riding. Quote
ryan954 Posted January 22, 2015 Author Report Posted January 22, 2015 And where can i get that bearing from? Quote
dirtydownunder Posted January 22, 2015 Report Posted January 22, 2015 If ya racing, why a serval and not a cheetah ? Id send the cylinders to redline for a port. Tell him what you want. His "clean up " ports can yeild good power. Quote
ryan954 Posted January 22, 2015 Author Report Posted January 22, 2015 I herd severals are more reliable Quote
