Hector_Vigil Posted January 19, 2015 Report Posted January 19, 2015 :shrugani:I have no low end power what so ever.... while one side is hot the other is barley warm. But once I get on the powerband it is fine just bog on low end. I adjusted my carbs to were it would idle a little harder and it seems to help a little. If I run it with no filter(1) it also gets better. (my filter is clean) My reeds and plugs are also good. I think I have a leak on the end part of my fatty because it would leave my pants with black stains. so can this be my jetting? a piston? Also my clutch is pretty worn but idk if that would matter. Quote
dailydrifter Posted January 19, 2015 Report Posted January 19, 2015 Clean and sync the carbs especially the pilot jets. I would also do a leak and compression test. Quote
Dirtsurferaust Posted January 21, 2015 Report Posted January 21, 2015 If one pipe is barely warm sounds like one side isn't firing till u get on the pipe That would give no bottom end and luke warm in one side and power coming on higher in revs Bad spark one side until revs come up I've seen it happen on my sons banshee One more thing to look at Quote
