Just got a new 4 mil banshee and I was hauling ass in 5th gear and the plug got fouled. I replaced the plugs and it won't start. It started first kick every other time. I put both chokes on and held the gas down and it will start run for a couple of seconds and die. It backfires sometimes too. It doesn't sound right when you kick it or it runs. Thanks for any help. Fresh rebuilt carbs and motor
If it backfires and does not sound right when it does start then check your flywheel as stated a couple of times above also need to do a compression test and make sure that is good. You dont usually foul plugs wide open in 5th gear!
YOU HAVE A TIMING ISSUE CHECK YOUR FLYWHEEL!!!!!!!!!!!!!!!!!!!!!
Not really tearing into it to check the flywheel key. Make sure you do not try and pull the flywheel unless you have the right puller! Do not put a jaw puller on it and try to get it off you will ruin it!!!
