banshee jetting
bpomps215
  • Replies 31
  • Created
  • Last Reply
Top Posters In This Topic
No need to get mad i was just asking
Not mad. There's plenty of questions you can and should ask. But in the time it takes for someone to respond, you could have read 10x what one person can tell you. Timing plate is a simple mod. It works from stock to fully built bikes. Can be done to your stock plate for free.
If you read up you can learn all this info and you'll be able to get an idea of what your doing.
Nothing worse then being spoon fed everything to go riding and breaking down. Now you have no clue wtf to do because all you did was do what you were told. No problem solving skills.
Got to admit sheerider11 is right
What size jets do i need for those and whats a timing plate what does it do weres it go ?
With timing plate you shouldnt have to mess with jets and with reeds you usually go 1 up in size on the pilots but like with all modifications you should check the jets by doing a plug chop
  • 3 weeks later...
anytime you go with aftermarket reeds and remove the reed plates you will need to go leaner- 1-3 sizes"smaller" on the main jets, its in the directions, as the reeds will open signifigantly more
rule of thumb on the needle clip is if its past the 2nd clip you need a bigger main jet, always make sure you are not to lean
Woah. Where did you get your directions?
