bpomps215
Everything posted by bpomps215
  1. Finnaly found what was wrong with the shee, turns out the cylinders were bored 30 over by the previous owner who told me they were stock, so i had put stock pistons in, now im redoing the top end with the right pistons and a good cylinder honing Sent from my iPhone using Tapatalk
  2. Im just going to bring the quad to my local motorsports repair shop im getting fed up and rather just pay to have it done Sent from my iPhone using Tapatalk
  3. I gues thats what im guno have to do Sent from my iPhone using Tapatalk
  4. Nevermind i found how to pressure test it, i did not measure the cylinders but they did not look like an egg shape the ring gap was correct, i just need to know were to start now Sent from my iPhone using Tapatalk
  5. How do you pressure test it ? Sent from my iPhone using Tapatalk
  6. Sent from my iPhone using Tapatalk
  7. heres the picture after i put the new pistons in Sent from my iPhone using Tapatalk
  8. The idle was going up and down to high then low
  9. I got it from harbor freight, when i got the tester i tested compression and it was 100-105, so i figured it needed a rebuild so took engine out rebuilt it then started the quad up was running and idling great then broke it in had no problems, then it was more smoke coming out of one exhaust then another then i road it and had it idling and it died and will not start again, it has spark and gas, so the only problem is compression, tested that and its 60-65 in both cylinders, now today later im going to take the top end off and see whats going on
  10. Im trying to post a pic of when i rebuilt it someone email me and i can send them to show you [email protected], and its a brand new compression tester
  11. I did replace all gaskets, im going to take it all apart today and ill let you guys no what i find
  12. Yes they were at the holding tabs
  13. I didnt bore it or anything just took old piston and rings out and put new ones in and replaced all gaskets
  14. Has oil and coolant, i know i put the head gasket on right, the quad was just idling and it seemed like one cylinder was going on and off then idled high and turned off
  15. I just did a full too end rebuild on my stock 03 banshee, after rebuild started right up and broke it in properly was riding had it idling then it died and hasnt started since, did a compression test and its only at 65 psi both cylinders, i did notice a constant white smoke coming out of exhausts when it was running, please help me i dont kno what else to do
  16. No need to get mad i was just asking
  17. What size jets do i need for those and whats a timing plate what does it do weres it go ?
  18. Im going to order a 230 main and the needle is set at 3, do you guys have any suggestions on what i can do to make better throttle response or to wheelie easier
  19. Ok thanks for all the help im going to do that ill let you kno how everything works out, my specific location is stamford conneticut
  20. I looked it up and found im at about 161 feet above sea level
  21. The coldest is probably in the high 20s it goes up and down like today is sopposed to be 50 and tomorrow 30
  22. I just have the banshee to mess around with i ride in a parking lot becouse theres no trails by my house and i ride in the snow around my neoborhood and stuff, there is about 27 half of an inch holes in the airbox lid
