Hey, So I recently ordered +2 +1 a arms im installing them today. On their website it says to use the stock dust caps so I did but it barelyt fits in the bracket and thats with a little bending. Anyways I got them installed and tightened up, the a arms wont move up and down without some force. Mind you these havent been greased, didnt want to do that until I knew I had everything set up right.  Any ideas?
http://imgur.com/nXBm3ap,XVrleVj
Tight is good. After new bushings and grease they should almost float in the air wherever you let go of them. Definitely don't over tighten them though. That usually results in stripped nuts.
