What's the first mods I should gO with? My shee is bored .40 I have a full dynoport 2:1 system and the four strokes don't even have a chance against me. Carbs are stock and the airfilter is a 2:1 crappy looking thing. It's got two layers so I really can't complain. I more than likely need to jet it although she idles nice. Handle bars are stock I definitely need some fatty bars. Can someone answer my jetting problem?
Get rid of the 2:1 system first. The most basic and cheapest mod would be to advance your timing. Most people advance it +4 with aftermarket pipes but I am unsure if the 2:1 system effects it. If you are a duner and are looking for power get some pod filters and drop the airbox. You will have to get jetting info from someone else.
Dont base all of your jetting off of how it idles...
I would also ditch the pipes if money allows it...you can way better systems cheap on here in the classifieds
Only way to base your pilot jet is by if it idles at a nice RPM without rich or lean bogging. If you have a lean bogg and your air screw in more than .5 turns in then go up a size, it your out more than 2.5 turns then drop a pilot size.
He said he liked how quiet his 2:1 is so maybe the Hush kit would be his thing. You also suggested T6's and work for T6's.
Screw all you haters my 2into1 is the shit!!! It allows me to ride in the woods like a four stroke all my riding areas are mostly creek beds and hollows I live in Ohio so I'm in the Appalachian mountains
Then why ask if you say acrew all the haters? They are answering your questions..
