sheerider11 Posted September 23, 2014 Report Posted September 23, 2014 Eh? I'm not understanding what you're saying here... Sent from my DROID RAZR using Tapatalk i did it by eye thinking I did good. Got that and used it. I was far off. And it took forever to get them perfect. Quote
J-Madd Posted September 23, 2014 Report Posted September 23, 2014 You can use a method like the OP described. I've seen it done. That being said I just eyeball it. Quote
Atomic Monkey Posted September 24, 2014 Report Posted September 24, 2014 I made nipples that fit in the boots where the crossover tube goes in. 1/2" copper pipe fits well. Then I use a Motion Pro sync gauge. When I first used the sync gauge on the banshee, I ended up with unequal turns on the air screws to get the idle mix right. I've since then changed pilots, and found the whoever installed the originals left a burr that obstructed flow. So I'd say the sync tool would also be good for diagnosing certain idle and off idle issues as well. Quote
O/CbansheeRider Posted September 24, 2014 Report Posted September 24, 2014 I did the eyeball thing then I used my old gauge from my Volkswagen days and I could tell the difference in throttle response.i just set idle speed check vacuum and adjust till there even. Then set slides to lift at same time. Sent from my iPhone using Tapatalk Quote
Zillaguy Posted September 28, 2014 Report Posted September 28, 2014 You definitely can sync carbs on a multi cylinder engine using a monometer. Techs have been using this method for years.. works perfectly. Quote
Brian Mcgowan Posted October 2, 2014 Report Posted October 2, 2014 they sell a tool on ebay to synchronize multiple carb set ups. just use inlet vaccume. no drilling. most of the stuff I work on does have ports and I use a vaccume mate. but like I said their is a tool that you can use without drilling Quote
