I am running a Redline 421 Serval with 33 pwks and off the top of my head i think i have a 48p and a 165 main with cel needles.Tthe plugs show a touch rich but id rather be safe then sorry.
  • Replies 40
  • Created
  • Last Reply
Top Posters In This Topic
Tried swapping leads again and fitted a brand new coil
No change
When you pull a lead off each cyl it sounds like the right side is firing half as much as the left
This doesn't change when you swap leads to other side
About to swap carbs and see what happens
I swapped the carbs and the issue seems to follow the carb
I pulled these off without spilling any to check the levels
Does it seem right?
Will be doing a leak down later this arvo just to rule that out
I did a leak down and it was up the shit
Pulled intakes apart re did everything dropped from 6psi to 5.5psi over 10 mins is that ok ?
Idles a bit higher now seems better but will have to wait til tomorrow to test as not enough room out the front
Still doesn't seem to have the go it should though
