zack98banshee Posted September 8, 2014 Report Share Posted September 8, 2014 just put a fresh stock bore top end on my 98 banshee with wiscos and rebuilt both carbs, stock everything. runs great when first started up then left cylinder putters out, overflow from carb starts leaking until you tap the side of the bowl then it stops and runs great for a little bit, I figured the float was sticking but I took it apart numerous times and it isn't, its all perfectly clean and new internally. sometimes it will die out with no gas coming from overflow, then tap the carb and its fine again. help Quote Link to comment Share on other sites More sharing options...
Larry's Shee Posted September 8, 2014 Report Share Posted September 8, 2014 No matter what it's float related. Either float hitting bowl, sticking on pin/posts, maybe leaky, wrong level, or your chinawanese needle/seat isn't worth a shit. Quote Link to comment Share on other sites More sharing options...
