ok just bear with me my bother bought a 421 serval cub kit form FAST racing it frocking rips. so I went out ant bought a banshee I has anthena 392 kit on it (nothing cool) but I wanted to know if I got it ported would it be any better are complete waste. if so please say thanks.
Well, The Athena name sure has a lot of heritage and experience so naturally they would want to try the banshee market. To be honest I'm surprised it took them as long as it did. But their stuff doesn't quite hold a candle to the other stuff available. However they are better then stock if they have decent nickasil in the bore. They don't have to radical of a lay out so you can still get some bottom end. Plus they got the triple exhaust which is nice and allows a builder to do some good things with volume. They are relatively newer in a competitive market, so not to many guys have messed with them. There has been a few guys to get them to run ok, though. You'll probably be able to find someone who can port them and get them to run well. But you might be happier selling it and starting with a serval your self.
Edited by trickedcarbine
I'm most likely going with the serval in time. just some other Q? are the 421 kits servals are cheetah cubs from Herr jugs. I know about the ones from FAST racing.
It's not the cylinder that determines the fuel usage. It's the head/dome set up. I think I have seen Athena's available with domes for pump gas as well as race gas. Do you know what the current set up is compression wise?
