Rfnh Posted August 21, 2014 Report Posted August 21, 2014 I Recently got my engine rebuilt because i broke a rod so i added a new crank, pistons, cool heads, vforce 4 reeds, new stator with timing plate. The issue is that i wont start. It gets a spark it has compression. for the last two days ive been trying to kick it over and nothing. At first i checked to see if i was getting a spark i was so i went to check compression i didnt use a gauge to check it i just a finger in the hole technique. when i remove my plugs they were dry. So i recheck my pick coil setting and spark plugs everything checked out. Now im stomped cause im not getting gas the the cylinders. Some one help please lead me in the right path the get my shee back running Quote
Surfrjag Posted August 21, 2014 Report Posted August 21, 2014 Check to see if carbs are filling with fuel Quote
BUILDER Posted August 21, 2014 Report Posted August 21, 2014 You get the float bowls back on the right side? Choke tube installed between carbs? Quote
WINDYCITYJOHN400 Posted August 22, 2014 Report Posted August 22, 2014 Did it run after the rebuild?…..Or are you trying to fire it for the first time since the rebuild? Quote
