Banshee SE Posted August 9, 2014 Report Share Posted August 9, 2014 I got another bike.it has good compression 119psi and 120psi, start first or second kick but the motor is too noisy. Im trying to figure it out why is so noisy and I would like to know if this play is normal. Clutch basket is pretty firm no play at all. Crank shaft bearing look to be good. Piston slap maybe no matter the good compression? https://vimeo.com/103007354 Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted August 9, 2014 Report Share Posted August 9, 2014 Nothing wrong with that amount of play. That won't make excessive noise. That basket and inner hub look chattered to fuck though. The itch creep on you at all? Also check the kicker gear behind the basket. Also look to see if the primary gears are the same lash group. Quote Link to comment Share on other sites More sharing options...
Banshee SE Posted August 9, 2014 Author Report Share Posted August 9, 2014 Nothing wrong with that amount of play. That won't make excessive noise. That basket and inner hub look chattered to fuck though. The itch creep on you at all? Also check the kicker gear behind the basket. Also look to see if the primary gears are the same lash group. basket looks great, absolutely not play and no groves on the walls. I was thinking in the spacer, the bronce one attached to the basket, this is the only thing I can think could cause this play. Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted August 9, 2014 Report Share Posted August 9, 2014 What? that basket and hub look grooved to shit. Which could give you excessive noise. Quote Link to comment Share on other sites More sharing options...
Banshee SE Posted August 9, 2014 Author Report Share Posted August 9, 2014 (edited) What? that basket and hub look grooved to shit. Which could give you excessive noise. it looks like in the video but these groves are very light. I would say this is dirt or grease from the clutch plates. Edited August 9, 2014 by Banshee SE Quote Link to comment Share on other sites More sharing options...
Banshee SE Posted August 9, 2014 Author Report Share Posted August 9, 2014 Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted August 9, 2014 Report Share Posted August 9, 2014 Ahh, you're good. Quote Link to comment Share on other sites More sharing options...
toytech Posted August 9, 2014 Report Share Posted August 9, 2014 The rubber cushions are probably worn out and causing noise. Quote Link to comment Share on other sites More sharing options...
Piediddy Posted August 9, 2014 Report Share Posted August 9, 2014 If the basket or hub is making the noise shouldn't it stop when you pull in the clutch? Quote Link to comment Share on other sites More sharing options...
toytech Posted August 9, 2014 Report Share Posted August 9, 2014 the basket turns even when the clutch is disengaged Quote Link to comment Share on other sites More sharing options...
Piediddy Posted August 10, 2014 Report Share Posted August 10, 2014 Rite, sorry I meant would their be a change in the noise? Maybe a little quieter? Thanks Quote Link to comment Share on other sites More sharing options...
