banshee 421 cub
mx887
I have a 421 cub 4mm long rod banshee on alcohol the bike is pushing 100hp
.noss head with 18cc redline
.421 cub cylinders ported
.v3 carbon reeds
.40mm pwk pump carbs with billet fuel bowl
.fuel pump
.new top end
.pingel fuel valve
.ricky stator
.billet timing plate
wiseco crank with tz bearings
.direct drive lockout case
.mattoon lockout
.billet water pump
.carbon water pump cover
.billet water cover drain
.2-5 dune over ride trans from redline racing
.over sized radiator
.Blue Silicone Radiator Hose
.530 o-ring chain and gears
.Chariot Chain Tensioner
.lonestar billet swingarm +10
.marvin shaw shock in the back
.lonestar axel
.billet back hubs, lock nut, chain hub, brake hub
.lonestar ALUMINUM AXLE CARRIER
.custom seat
.raptor body
.front works shocks
and more please call me at 801-232-9one88 for more info or to make an offer $4000 OBO
text for picturs
