Rapture Posted July 9, 2014 Report Posted July 9, 2014 Im going to paint the cases and calipers in yellow using VHT brand paint. The caliper paint is rated up to 900F, but the engine enamel paint is only rated to 550F. Will i be ok to use the caliper paint to do the engine as well? I want all parts to be the same yellow, so ideally using one type of paint to do all components. http://www.vhtpaint.com/products/engineenamel/ http://www.vhtpaint.com/products/caliperpaint/ Quote
fastbanshee8 Posted July 9, 2014 Report Posted July 9, 2014 The caliper paint will work, as long as you cure it correctly. The cases will get hot enough to cure it, with a bit of run time. Quote
