Ban96shee Posted June 25, 2014 Report Posted June 25, 2014 Hello everyone. I have recently bought a yamaha banshee. Anyway I am worried that the jetting may be off, and I want to re adjust it. The guys I bought it from had their jetting at a 240 main. Uni pod filters Fmf fatty pipes and silencer 19cc domes V force reeds if I remember correctly Boost bottle idk if that matters Mixed at 32:1 with yamalube 2r, 93 octane. Height is sea level Temp is about 70-80 degrees I was wondering what you guys would recommend for the main jets, pilots, needle clip. Any advice is great, thanks. Quote
Ban96shee Posted June 25, 2014 Author Report Posted June 25, 2014 Also forgot to mention the pods are not inside an airbox they are just coming off the back of the carbs. Quote
trickedcarbine Posted June 25, 2014 Report Posted June 25, 2014 290 ish main, second from bottom clip on needle, 27.5 pilot. Quote
BUILDER Posted June 25, 2014 Report Posted June 25, 2014 I have done several of these same setups here in the last few weeks. One thing I have found is the last two bikes I jetted with FMF pipes wanted a larger pilot than most the pipes I have used. You main will end up right around a 270 but like tricked said start at a 290 and adjust down from there. You will end up with a 27.5 or a 30 pilot but I am guessing it will like the 30 pilot a little better. Quote
Ban96shee Posted June 25, 2014 Author Report Posted June 25, 2014 Thanks for the replies. I recently ordered some jets from jetsrus. Quote
