Does anyone know where to get clear hosing for the radiator (must withstand the temp), also im looking for clear gas lines
also, how does the stock impeller fail ? Does it shatter ? if i was to put a needle bearing in there instead of the bushing, would that fix the problemo?
I would check your local home depot or lowes for the coolant hoses...dont know how flexible that shit is gonna be...it tends to flatten out...you might have to use elbows to get thw hoses routed correctly...
if you go this route make sure you get the high temp stuff, not the clear shitty ass water pipe that is going to blow off. The hose is VERY flexible if you get the correct stuff. I got mine from nastyracing a few years back 3 Years i think. The person I sold them to still runs them and they look like new.
  • 3 weeks later...
