stealthboy Posted June 20, 2014 Report Posted June 20, 2014 (edited) Hi guys...i have a fresh build going together and hoping someone will help me out with a starting point for the jets. 1300 elevation athena 392 big bore kit stock stroke crank welded and trued K&N powerlid weisco clutch basket +4 timing plate with lightened flywheel and 200watt stator trinity single carb kit with pj36mm keihnin dynoport 2 into 1 exhaust all trail riding my athena big bore kit came with domes but I'm not sure what cc they are...how can I tell? I would really appreciate any advice you can give me for a starting point....thanks in advance Edited June 20, 2014 by stealthboy Quote
RKJLOW Posted June 20, 2014 Report Posted June 20, 2014 There engraved on the bottom ring of the dome on pro design ones Sent from my SGH-M919 using Tapatalk Quote
stealthboy Posted June 20, 2014 Author Report Posted June 20, 2014 There is no markings on these domes....is there a way to measure? Sent from my SCH-I605 using Tapatalk Quote
sleeper06 Posted June 22, 2014 Report Posted June 22, 2014 A good stsrting point would be 200,45 pilot dek needle but your putting together an oddball set up from most so hope you have good tuning skills, also if theres no marking I would put it together and check static compression, if your asking how to find out my guess you dont have the equipment to cc domes Quote
