RKJLOW Posted June 20, 2014 Report Share Posted June 20, 2014 This isn't a chop this is from my first ride on my rebuild.. Planning on doing a chop next weekend.. Just looking for some input to ease my mind. My mods are 21cc domes plus 4 timing fmf fatties vitos ss Pistons vitos dual stage reeds 320 main 30 pilots airscrews 1.5 from seated this was about a hour of ride time man so far I'm loving how this build is running. Sent from my SGH-M919 using Tapatalk Quote Link to comment Share on other sites More sharing options...
RKJLOW Posted June 20, 2014 Author Report Share Posted June 20, 2014 Sent from my SGH-M919 using Tapatalk Quote Link to comment Share on other sites More sharing options...
RKJLOW Posted June 20, 2014 Author Report Share Posted June 20, 2014 I'm around 1300ft Sent from my SGH-M919 using Tapatalk Quote Link to comment Share on other sites More sharing options...
RadarRacing Posted June 20, 2014 Report Share Posted June 20, 2014 That appears to be quite rich. All the brown out towards the end can be rich on the needle and or pilot with idle time. I think you can safely go down on main and raise the clip on the needle. I would usually say do one step at a time but if that was a new plug and you ran it hard thru higher gears and killed it, coasted to a stop then it is a couple jets rich. Start with a plug that is new or only has 3 or 4 passes on it. Quote Link to comment Share on other sites More sharing options...
