IMG_20140518_164217-1.jpgIMG_22606963255583.jpeg set of skat trak 16 bar staggared terrain trak chissel dirt drag tires,25" tall 79 RO, on douglas blue label 12×12 rims, rim to tire bead screwed for no slip 400$ alone just in chissels tires still havevthe hairs on em, needs to go , I need a taller tire w/more rollout 650$ shipped
I think you need to move your wheels just a touch farther more narrow.. For ultimate aerodynamics you need to get the tires closer to the hubs.
lol haha shayne!!
Mike was this a SNOMO motor?
EDIT, just saw the sprocket size...  What CC?
yeah steve off the sno mo I built an 890 rotax triple this spring, tires are no longer workin to well with the new powerplant, sprocket is like 13" in diameter LMAO!!!
Sweet tires. Try going down in rear sprocket size it will lengthen out the gearing.
It's snomo powered. Although your thought is correct the snomo clutching doesn't make it that simple.
Sent from my SCH-I545 using Tapatalk
  • Like 1
