Differences: Long rod vs short
I'm curious about the two different options that come with a +4 crank. What are the advantages or disadvantages between the short rod or the long rod?
I will eventually drop a +4 into my motor but I would like to understand the options better.
My response was to your post about what you got out of that article. piston availability is a moot point on a stock cylinder and the longer rod actually opens up piston options if running a stock stroke cub or cheetah with a 68mm bore.
I just did a ton of reading of old posts. I didn't think to search for the subject. It does look like a long rod setup would be the better choice.
Try Google search next time . Add "bansheehq" to the search. it'll help you find the info you require easier .
99.9999% of any questions you or anyone else ask have already been asked and answered on here....it's just using the easier search function.
Sent from a van down by the river
