SquatchXXL Posted June 10, 2014 Report Posted June 10, 2014 Hoping someone can help. Shes popping and bogging down at the mid rpm range when the powerband should be kicking in. Has new pistons rings gasket and head. carbs have new guts and seem to be synced right. Was told its coil packs. How do I test that? Was told by person I bought it from that its a new coil. Please help? Thank you. Quote
Strm Trpr Posted June 10, 2014 Report Posted June 10, 2014 First verify that there is a hose connecting the two carbs that is parallel to the choke. If yes. Pull the choke out fully and try and ride it. If it gets into the powerband with less popping, you're jetting is lean. Stop and report back with all mods and what jets are in the carbs. Quote
03DMshee Posted June 13, 2014 Report Posted June 13, 2014 He cant update till he orders new top end due to lean condition.... Quote
SquatchXXL Posted June 13, 2014 Author Report Posted June 13, 2014 Haha thats funny. The top end was just done. What it wa...the asshole I got it from hooked the coil up wrong. Now just need to tweak carbs but shee runs much better. Quote
