Im getting ready to tear apart my 2003 banshee for the first time and im wanting to add a new welded crank, a good set of engine seals and gaskets, piston kit.
Current setup:
toomey t6 pipes
there jet kit
air box air vents per toomey recomendations
Stock carbs
vforce 4 reeds
chariot 21cc domes
vitos timing advace key +4.
im wanting a nice reliable trail machine that can get you in a little trouble from time to time.  i dont want a jetting nitemare or any reliablilty issues.  i was thinking of doing the following and i need your input
Vitos Super Stock Ported Piston Kit(supposedly 8hp gain, not sure nout that lol)
Welded crank
Good crank seals? need help on this
if there are any other mods while i have it apart please let me know.  I dont know who does a good welded crank, and what is a good brand of seals?  thank you in advance.
Screw the Vito's pistons. I'm a wiseco fan. Welded crank. Maxloads. Port. Pro mod trans.
the vitos are wiseco, just molded different to there specs....who would you suggest for the welded crank, thank you
They worked fine as long as your motor doesn't already have the exhaust port raised. I installed some in a drag ported stock cylinder and man that thing hit like a freight train. ZERO bottom end and strung the fuck out on the top end. Pulled them out and installed new wiseco's and it tamed it quite a bit.
Ditch that +4 key and get an adjustable timing plate.
Sent from my SM-N900P using Tapatalk
