With 20cc domes, you're still able to run 93 octane right? it's just when you drop below that you should start doing 50/50 race gas right?
It depends on your elevation, timing, and porting. If you are above 800' elevation with stock timing, you should be okay with 20cc domes and premium pump gas. Do the ProLite pistons raise the compression?
