I am doing a complete part out of this 2004 421 Cub.  It is loaded with goodies.  I will be adding parts and prices in the next few days.  Here are some parts to get this going.  Prices don't include shipping or fees.
Over ride trans  N Down 1-5  $150................Has some damage.....a couple of teeth or gone on a gear, the idler gear is worn, the shaft is bent.  Great deal if you can repair yourself.  Comes with forks and drum.  Cut by Ohton I believe.  I have more pics if you want to see some more.  Just PM me if you want more pics or if you want something.
Billet basket   $100
+10 Swing Arm   $200
Works front shocks $200
Braking Rear Wave Rotor  $45
+2+4 extended rear axle  $120
V force 3 Reeds  $100
Slingshot Lockup $150 with heavy springs
Pancake bearing for clutch $25
Trail Tech Bar Mount for Oversized bars with key and switch  $40
Cascade Billet Shifter  $25.........the threads are damaged so the bolt runs a nut on the back side...........splines are good
Black PC Dog bone  $25
Polished Roundhouse bearing carrier with brake plate  $80
Almost new front dirt tires and stock rims  $120
Razor type front sand tires $100
Wire Harness $35
  • Replies 48
  • Created
  • Last Reply
Top Posters In This Topic
PM replied on axle.  I am not sure on the brand.  Does anyone know or recognize the part number listed on it?  I thought it was a Lonestar but I am not certain.
Cylinders are good but may be sold.  I will know today for sure Dmax.
Crank is pending.
A arms are available for only $200 if anyone wants them.  The joints are good but 3 boots are torn and should be replaced.  PM me if you want them.
Here are some more parts from this bike.  PM me if you want anything or need more pics or info.  Thank you.
Revalved and resprung oem shock for +4 swinger 180-200 lbs.    $100
Chain guide lower one  $15
Chain slider Upper  $15
OEM Black rear hubs  $30
OEM Coil   $20
OEM CDI Black Box  2004 model  $75
Clutch perch and lever  $10
Complete Rear Brake setup with Cascade billet block off plate, stainless steel extended brake line  Complete setup  $80
21 cc Domes.......No markings to indicate 21cc but that is what I was told.......$40
IMG_4338.jpgIMG_4337.jpgIMG_4335.jpgIMG_4334.jpgIMG_4333.jpgIMG_4332.jpgIMG_4331.jpgIMG_4330.jpgIMG_4329.jpgIMG_4336.jpg
More parts!!!!
OEM Bar Switches  $20
OEM Swing arm pivot bolt and nut....Great Condition....$20
Black OEM Grab bar  $20
Stock carbs with cable and Tors deleted.........$50
OEM Thumb throttle......Great Conditon     $25
UNI clamp on foam filters for oem carbs   $20
