TwistedMethods Posted May 21, 2014 Report Posted May 21, 2014 . Ok I've been looking at the manual about setting the clutch . When I pull my lever it's like it doesn't ingage so I took the clutch cover off tried adjusting it lined up the arrows an still it don't engage it's like my cables to long I'm not understanding it please help Sent from my iPhone using Tapatalk Quote
TwistedMethods Posted May 21, 2014 Author Report Posted May 21, 2014 Lmao swear I'm blonde sometimes I got it one question tho when you pull your lever in how far should the pressure plate pop out ? Sent from my iPhone using Tapatalk Quote
TwistedMethods Posted May 21, 2014 Author Report Posted May 21, 2014 K I got it set up properly now but when I put it in 1st an pull the clutch it's not fully ingageing cable is in proper now Sent from my iPhone using Tapatalk Quote
special06shee Posted May 21, 2014 Report Posted May 21, 2014 Lmao swear I'm blonde sometimes I got it one question tho when you pull your lever in how far should the pressure plate pop out ? Sent from my iPhone using Tapatalk About yeh __ much Quote
TwistedMethods Posted May 21, 2014 Author Report Posted May 21, 2014 Got any ideas why it's not fully ingageing ? Sent from my iPhone using Tapatalk Quote
TwistedMethods Posted May 21, 2014 Author Report Posted May 21, 2014 Any help/idea's why it's not fully engaging please Sent from my iPhone using Tapatalk Quote
special06shee Posted May 21, 2014 Report Posted May 21, 2014 Adjust the rod in center of pressure plate to give it more throw. Quote
TwistedMethods Posted May 21, 2014 Author Report Posted May 21, 2014 I tried all the way in and at different points Sent from my iPhone using Tapatalk Quote
special06shee Posted May 21, 2014 Report Posted May 21, 2014 Right cable? Did ya put the ball in before the rod? Somethings not right. Quote
special06shee Posted May 21, 2014 Report Posted May 21, 2014 Have the marks lined up on the hub and pressure plate? You do know the pressure plate goes on a certain way?? Quote
TwistedMethods Posted May 21, 2014 Author Report Posted May 21, 2014 There's 3 arrows on the pressure plate. Sent from my iPhone using Tapatalk Quote
special06shee Posted May 21, 2014 Report Posted May 21, 2014 Unbolt pressure plate and turn either way one bolt hole. Bolt back up and youll be good Quote
TwistedMethods Posted May 21, 2014 Author Report Posted May 21, 2014 Does somthing go here ? Sent from my iPhone using Tapatalk Quote
J-Madd Posted May 21, 2014 Report Posted May 21, 2014 That's been drilled on but it's just an oil hole. Quote
