tci Posted May 17, 2014 Report Posted May 17, 2014 Hey fellas been having problem after problem. its a 99 ran great for a little while now the list goes on... i just finished installing a used OEM stator because i tested the aftermarket one the was in it and it was hugely out of range. I was suggested to test it by Kan Powersports on facebook because he and i both felt it would shut down from heat. Anyhow it would run for a short while (maybe 10 min) then die. then fire only 2-3min later. Now that i have this used OEM unit in it fired first kick idled warmed up and revved great. Today i went and fired it up and let it warm up while i buttoned up the plastics to take it for a test ride. Once i finish i hopped on and gave the throttle a flick and it revved up the just dropped dead like the ignition cut out. My multi-meter took a dump so unable to test anything till i get a new one. Just curios if anyone has had similiar problems or may know the gremlin thats haunting my Banshee. Quote
turbowrenchhead Posted May 17, 2014 Report Posted May 17, 2014 You have to start with the basics again. Check spark then check fuel. No spark then you need your volt meter to run ohm tests. Quote
