Turbo,Pipes,Reeds,Carbs,Lockup,Stator Cover
Cleaning out the garage and looking to get rid of some parts. PM me with any questions
Aerocharger 53 series turbo- $1100 shipped
I bought it from Brian Stimbert from quality powdercoat with plans to build a turbo 350. Too many other builds on the table to start another project. Not much run time on the turbo.
Shearer DM pipes- $375 shipped
These were ran on my 14mm DM, few minor dings but nothing major, has an adapter plate so you can swap on silencers if you ride in the dunes, mounts have been re welded.
39mm Keihin carbs with powerjets- $300 shipped
one float on each carb was removed to help get more fuel in, .122" dump, setup for gravity feed alcohol, 1 carb has slight damage where the filter clamps on but was repaired and has never caused me any issues, left carb float bowl nut has been welded and filed down smooth so it doesn't interfere with clutch arm, bottom fitting for power jet line will be installed before shipped out.
cr 500 V-force reeds with 39mm intakes- $175 shipped
Reeds and intakes came off my DM and are both in decent condition
Direct Drive lockup clutch- $60 shipped
Good working condition
Chariot bearing support stator cover- $150 shipped
Decent working condition
http://i1113.photobucket.com/albums/k513/macdaddyracing/photo_zps560ad388.jpg
http://i1113.photobucket.com/albums/k513/macdaddyracing/photo6_zpse773bcf3.jpg
http://i1113.photobucket.com/albums/k513/macdaddyracing/photo1_zpsc7081aae.jpg
http://i1113.photobucket.com/albums/k513/macdaddyracing/photo2_zpse6f9d633.jpg
http://i1113.photobucket.com/albums/k513/macdaddyracing/photo3_zps0d3fa4e7.jpg
http://i1113.photobucket.com/albums/k513/macdaddyracing/photo4_zps45a1f29f.jpg
http://i1113.photobucket.com/albums/k513/macdaddyracing/photo5_zps525eb8c1.jpg
http://i1113.photobucket.com/albums/k513/macdaddyracing/photo7_zpsfeb5ce13.jpg
Edited by MacDaddy racing
  • Like 1
When was the last time the turbo was serviced?
What spring is in the waste gate?
How many shims are on the spring?
Does the waste gate have any sort of bleed valve on it?
What is the SN?
Sent from my SCH-I545 using Tapatalk
