bansheelover Posted November 14, 2003 Report Posted November 14, 2003 Just after i slapped my tr-6's on i started having trouble with one of my cylinders. It would keep back firing and each time i pulled the plugs , this one was oil soaked. After that i switched the plugs in the cylinders and it did the same thing , only this time onthe other side, so i figured it must be plugs. I bought a new set after that and they lasted a week or 2 , then it did the same thing, on the same cylinder. I thot maybe the premix wasnt mixed well enough at first but that wasnt it. I dont even know where to start!! Has anyone ever had thios happen before??? Quote
Big Blue Posted November 14, 2003 Report Posted November 14, 2003 Check your jetting and clean your carbs, didnt have a bit of trouble when i put mine on. Quote
bansheelover Posted November 14, 2003 Author Report Posted November 14, 2003 what size jets are u running?? im using 280 's and my air screw is 1.5 turns out im also near sea level Quote
wheeleymaster99 Posted November 14, 2003 Report Posted November 14, 2003 i'm hveing the same problem other than a set of plugs laste me about 15-30 min someone tolh me that its the stator so i got a new one and dident help any so if you fid out whats the prob post it Quote
94BansheeRider Posted November 16, 2003 Report Posted November 16, 2003 What other mods do you have? Normally the pipes come with a jet kit. At least my T5's did. Sounds like you are running way too rich. Rejet and maybe remove your airbox lid also. Hopes this helps. Somebody else is probably alot more knowledgable than me Quote
wheeleymaster99 Posted November 16, 2003 Report Posted November 16, 2003 i'm running 290 main and 30 piot Quote
wheeleymaster99 Posted November 16, 2003 Report Posted November 16, 2003 i'm running 290 main and 30 Quote
94BansheeRider Posted November 16, 2003 Report Posted November 16, 2003 I am running 280's, clip on the 3rd or 4th needle groove. I can't remember what the pilot is. I have yet to foul a plug with this setup. 290's seem rich for use with the pipes. Is the rest of your bike stock??? Quote
bansheelover Posted November 17, 2003 Author Report Posted November 17, 2003 ya the rest of my bike is stock. I guess ill try removing the air box lid first and see what happens first. I thot at one point of going one spark plug hotter but i dont want to pop a piston. It sounds like all u guys are runnin almost the same as me so i dunno what it could be Thanks for the info guys Matt Quote
