What jets should I use?... modification are, Toomey t5s, boost bottle, boysen reeds in stock cages, k&n air filter in stock air box, and TORS elimination kit.... I'm currently using 27.5 pilots and 310 mains, it runs good but sputters at 2/3 throttle in 4th and 5th
Sent from my SCH-I605 using Tapatalk
I'm not the best at jetting but I had a setup very close to yours and I was able to make my banshee pretty quick. I had the stock size pilot jet, stock air screw setting, (I believe 1 3/4 turn out) and a 300 main, but I was running k/n pod filters and no boost bottle. I know to that elevation also plays a part in jetting and also the temp that your running it at.
read up on the boost bottles. I thought that I read that there isn't any benefit from it.
1. Ditch the bottle.
2. Do you know how to "read" plugs or plug chop?
3. What needle clip you at?
4. Lid on? Snorkel?
Being on the slightly rich side allows allows a safety factor. Should end up at 290/300. No one can tell exactly what you need.
If this 'shee is new to you a comp test and leakdown test wouldn't hurt either.
I have a set of 300 mains. Ill try those. Needle is on the middle clip, I'm using the stock air box and snorkel, it's wet where I ride.... ditch the bottle?? Are they no good?
Loose the boost bottle...
Here in lower mi you should be around a 290main
27.5 pilot
air screw at 1.5 turns
needle on the middle clip
This is my first banshee n burnt a hole threw the top of piston here is my setup
I have cpis for pipes
Vforce3
K&n
35 mm keihen air striker pwk
68mm vitos piston
10mm vitos stroker
Main jet 185 not sure what pilot is?top end wasnt really good 5th n 6th alot of sputering
I need help big time can some one help
Port timings to help, pilot should be around 45 , main start with 172 , cel 4th clip, .most important thing is a pressure test on that motor so u dont melt it down.there are people on this site that sell them or u can make ur own. Then u need to be sure you have solid grounds on your electrical system and yout plug caps ohm out correctly. More times than not people bring t here bike to tune and its not a jet problem at all its either an air leak or electrical so b4 you chase your tail jetting get that out of the way
