Did it run before top end?
Disco TORS brain on left frame by tank, throw  away.
Somewhere on here should be able to find values for stator test. Even if you have to use Google + BHQ, because the search function still sucks here.
Make sure ALL connections are clean & tight, consider dielectric grease on them. Clean ground at coil, or better yet add ground from coil back to engine.
  • Like 1
