Piediddy Posted March 25, 2014 Report Share Posted March 25, 2014 Anybody have one? How does intakes and carbs line up? Can I run inframe pipes? Thanks Quote Link to comment Share on other sites More sharing options...
Piediddy Posted March 26, 2014 Author Report Share Posted March 26, 2014 Thanks, what intakes, reeds and carbs you running? Quote Link to comment Share on other sites More sharing options...
sstaton1983 Posted March 26, 2014 Report Share Posted March 26, 2014 (edited) Anybody have one? How does intakes and carbs line up? Can I run inframe pipes? Thanks I see a few running in frames with no problems. Edited March 26, 2014 by sstaton1983 Quote Link to comment Share on other sites More sharing options...
slobanshee Posted March 26, 2014 Report Share Posted March 26, 2014 Cheetah here. Works fine Quote Link to comment Share on other sites More sharing options...
10milmike Posted March 26, 2014 Report Share Posted March 26, 2014 If your run Shearer inframes they hit the carbs alittle. I ran my Cheetah for a few years with inframes on with no problems. Use UPP intakes and vforce 2 or 3 reeds whatever one you want. And PWK carbs. With size Cheetah are you running? Sent from my Samsung Galaxy note 3 Quote Link to comment Share on other sites More sharing options...
10milmike Posted March 26, 2014 Report Share Posted March 26, 2014 Here is my old set up with my inframe pipes. Sent from my Samsung Galaxy note 3 Quote Link to comment Share on other sites More sharing options...
Piediddy Posted March 26, 2014 Author Report Share Posted March 26, 2014 Thanks guys, it's a 10mill and I have new CPI's Inframes. I might be buying it this weekend and wanted to make sure it would work in a stock frame. 10MilMike you have a stock trans or override? Quote Link to comment Share on other sites More sharing options...
10milmike Posted March 26, 2014 Report Share Posted March 26, 2014 When it was like that it was a stock tranny. That was my dune set up. Sent from my Samsung Galaxy note 3 Quote Link to comment Share on other sites More sharing options...
10milmike Posted March 26, 2014 Report Share Posted March 26, 2014 Your CPI's are they big bore or small bore? With a 10mil you want big bore small flange. Sent from my Samsung Galaxy note 3 Quote Link to comment Share on other sites More sharing options...
Coupelx Posted March 26, 2014 Report Share Posted March 26, 2014 I currently run one. Everything clears alright. Filters may be a bit close to the pipes. Quote Link to comment Share on other sites More sharing options...
Piediddy Posted March 26, 2014 Author Report Share Posted March 26, 2014 Thanks coupelx, Mike they are small bore cause when I ordered the CPI's I planned on building a Cub. But this deal might be too good to pass up Quote Link to comment Share on other sites More sharing options...
10milmike Posted March 26, 2014 Report Share Posted March 26, 2014 Small bores are not going to work on a 535 cheetah. Sent from my Samsung Galaxy note 3 Quote Link to comment Share on other sites More sharing options...
Piediddy Posted March 26, 2014 Author Report Share Posted March 26, 2014 It would be down on power? Different curve? I mean I understand there is a reason they make big bores. Just thinking should I wait and do a Cub? Or if Cheetah is worth messing with selling or trading pipes. Quote Link to comment Share on other sites More sharing options...
special06shee Posted March 26, 2014 Report Share Posted March 26, 2014 The small bores on a 535 will hold too much heat Quote Link to comment Share on other sites More sharing options...
