christy Posted March 23, 2014 Report Posted March 23, 2014 I recently bought a 1997 Banshee with no TORS and no parking brake. Problem is the bike always seems to run as if the parking brake is still on. It bogs out at a higher rpm, just like when you forget to release the parking brake and try and run a banshee. Choke is in good working condition and the bike starts with one kick. The green/yellow wire from the cdi box is disconnected (actually it's cut and tapped) but I have another 1997 banshee that runs fine and I switched the cdi box to see if that was the problem and it still ran as if the parking brake was on. Looking for any ideas of what it could be. Must be one dumb thing I'm missing. Thanks for any help. Christy Quote
Larry's Shee Posted March 23, 2014 Report Posted March 23, 2014 Have you tried a different stator? Hows flywheel? Pick-up gap? Plug chop- plug read? Have you searched to ensure P brake is properly disabled? Quote
03DMshee Posted March 23, 2014 Report Posted March 23, 2014 I would also look into removing the harness and going through it...some people just snip it as far as they can and dont realize it can still short out especially if water is introduced Quote
christy Posted March 23, 2014 Author Report Posted March 23, 2014 P brake harness is removed. I'll look into the stator, flywheel and pick up gap. Quote
christy Posted March 23, 2014 Author Report Posted March 23, 2014 Not much of a knowledgable person on stators but this looks bad, right? Christy Quote
christy Posted March 23, 2014 Author Report Posted March 23, 2014 Fly wheel didn't look to good as well. Quote
