OK my 4 mil banshee wont start. I kick it and all i here is a loud pop. Its only one pop. Kicked it again Popped Loudly again(Only one pop). Wont start! what should i check first. im going to check the timing plate but waiting on my fly puller to ship to me.
New Spark Plugs
New chokes.
Mixed 32:1
Edit:It doesn't pop on the first kick. And i have to hold the throttle in all the way.
Edited by Dahz
I had one do this to me once and i went through allllll of the wiring over and over again - turned out the key switch was bad. Every now and then I would get an intermittent spark and it would make a loud pop.
After testing and you are sure your wiring and whatnot is not your issue, start testing your ignition system. Now might not be a bad time to do a leakdown test either. If it is extremely lean due to an air leak it could be causing these symptoms as well. Let us know what you find out. Good luck!
mine is and 87 banshee with a 91 motor. so mine doesn't have a key switch ill start testing my ignition any special tool i need to test it? Also i think i seen it leak from the carbs.im going to check it again.
You will need a multi meter for testing your electrical system, then download a service manual for specs. Go from there and if nothing is found start checking hard parts - ex: flywheel key (as mentioned) stator condition, carbs, jetting, etc. Let us know what you find out. Thanks and good luck.
  • 8 months later...
