postman26 Posted March 10, 2014 Report Posted March 10, 2014 I have a friend that has a 10mil crank with 121 robs on it. We was thinking that it suppose to have 120 rods what's the difference with the rods number's Quote
BANSHEE HP Posted March 10, 2014 Report Posted March 10, 2014 hot rods 121 rod is a 110mm rod. 158 is a 115mm rod you sure its a 10mm storke? post some pictures Quote
postman26 Posted March 10, 2014 Author Report Posted March 10, 2014 He say it is I looked at it and I know it's a hotrod crank and the rods has 121 rods on it Quote
BANSHEE HP Posted March 10, 2014 Report Posted March 10, 2014 hot rods doesn't make a 10mm crank. now it may have been stroked and turned into a 10mm but it doesn't sound like it being that it has stock length 110mm rods. Quote
camatv Posted March 11, 2014 Report Posted March 11, 2014 i have seen some very old hotrods 10mm cranks they are super rare but out there if you make crank weebs its NOTHING to reset the machine to add 5mm more stroke to the webb.. escpecially if its a cnc cut. 10mm should cost the same as a stock stroke . so should 4 mills. 1 Quote
