↑↑↑ These are nearly extinct, if you search the wanted adds you will find many of these posts with no luck unfortunately.  The couple pair out their they want as much as you could get a brand new set made for you. Contact Stellar or fireball for a set. If its for drag then tyson has the cheapest drag style J arms ive seen .
Why do guys use J arms for drag ? What's the difference ?
Less material=less weight. When it comes down to it every pound counts.
Sent from my DROID RAZR using Tapatalk
