BANSHEEBEEFM2M Posted February 23, 2014 Report Posted February 23, 2014 My boys building a 358 cub. Got the jugs and a ss regular rod crank coming. 64 mm bore. What pistons regular wisecos or does the cub top end require something different ? It'll be ran on race fuel. What size domes and what head would u guys recommend? Do we have to get custom domes ? Thanks. Sent from my N8000_WHTE_CKT using Tapatalk Quote
oldskool Posted February 23, 2014 Report Posted February 23, 2014 I'm thinking a 358 cub is a 65mm bore and should be a 513 series piston. 1 Quote
Finch Posted February 23, 2014 Report Posted February 23, 2014 i ran shelf domes on my 392 and did fine everyone is usually gonna recommend custom domes but if your not looking for every last hp and just something to ride i wouldnt worry about it granted they only cost 10 bucks more. Quote
BANSHEEBEEFM2M Posted February 23, 2014 Author Report Posted February 23, 2014 Thanks. And its a 64mm bore Sent from my N8000_WHTE_CKT using Tapatalk Quote
sheerider11 Posted February 23, 2014 Report Posted February 23, 2014 I just went through this with Cameron. I was going to get custom domes for my girlfriends bike but he said I'll never know the difference. But that was a stock cylinder with a trail port and Paul turners. I'm sure you'll notice with a cub a difference between shelf domes and custom domes Quote
#1JUANstunna Posted February 23, 2014 Report Posted February 23, 2014 My boys building a 358 cub. Got the jugs and a ss regular rod crank coming. 64 mm bore. What pistons regular wisecos or does the cub top end require something different ? It'll be ran on race fuel. What size domes and what head would u guys recommend? Do we have to get custom domes ? Thanks. Sent from my N8000_WHTE_CKT using Tapatalk http://www.cpindinc.com/pub/view_product/9?lm=3&name=CPI-6454 Piston Number: 513M06400 Quote
BANSHEEBEEFM2M Posted February 23, 2014 Author Report Posted February 23, 2014 Thank you Sent from my N8000_WHTE_CKT using Tapatalk Quote
BANSHEEBEEFM2M Posted February 24, 2014 Author Report Posted February 24, 2014 What size domes? Sent from my N8000_WHTE_CKT using Tapatalk Quote
BANSHEEBEEFM2M Posted February 24, 2014 Author Report Posted February 24, 2014 .sea level/110 octaine Sent from my N8000_WHTE_CKT using Tapatalk Quote
BANSHEEBEEFM2M Posted February 24, 2014 Author Report Posted February 24, 2014 Ss crank. The cub has a clean up port. Mikuni 34mm carbs bored to 35.5. He's runnin oof drag pipes idk what brand Sent from my N8000_WHTE_CKT using Tapatalk Quote
BANSHEEBEEFM2M Posted February 24, 2014 Author Report Posted February 24, 2014 yes. Welded. Sent from my N8000_WHTE_CKT using Tapatalk Quote
