I recently cleaned up my harness by removing the TORS wiring.  When I did this, I had to do a lot of searching to make sure I was removing the correct wires.  If I had this image below, it would have made life a lot easier for me.  Basically, you will unwrap your harness, cut these from it, then re-wrap the harness.  This is cleaner than just taping off the plugs.  This is only the TORS system and nothing more.  I hope this helps others out there looking to do the same thing.
