lectro99 Posted November 10, 2003 Report Posted November 10, 2003 What is better for the banshee 32:1 or 24:1?????? Quote
ledofthezep Posted November 12, 2003 Report Posted November 12, 2003 What are your mods & what are you mixing? Quote
bansheelover Posted November 12, 2003 Report Posted November 12, 2003 ive got a stock engine. the only mods i have are pipes so i run 32:1 and it seems to run ok Quote
evil Posted November 13, 2003 Report Posted November 13, 2003 if it aint broke, dont fix it 32:1 is fine. later Quote
wheeleymaster99 Posted November 13, 2003 Report Posted November 13, 2003 yeah that sounds good but it really depends on what kinda of oil you use i and you shoud get eaither castor or synthenitc depending on what kind of reideing you do. castor is supposed be better if you run at higher rpm and i would say mix it at 40:1 and synthenitc is supposed to help reduce wear in your enigen and i would mix that at 32:1. i use and recomend the castor but it depends on what kind of rideing you do. Quote
