hughmyron Posted February 9, 2014 Report Posted February 9, 2014 Well i ended up with 165 main jet its caramelish color after a 1/4 pass, tried a 52 pilot and i had to leave the air screw closed because it would drive funny. Now heres my main issue, if im lets say chillen well under the powerband in whatever gear and i just happen to go WOT it completely falls on its face and sounds like if you just turned it off. It only does this when i go WOT, if i creep into it it wont do it. I just got back from my friends house we were going to start riding and literally 10 secs down the block i go half throttle to pick up speed and the bike falls on its face and turned off and didn't turn back on, we tried to push start it, we checked it had spark. Does this sound like a needle position issue? Im running right now 165 main jet, 60 pilot jet, and needle in 3rd position. Quote
sleeper06 Posted February 9, 2014 Report Posted February 9, 2014 What needle do you have in the carbs, did you check compression , that sounds lean for a drag ported cub close to sea level , I would check compression that will let you know if you burnt it down Quote
sleeper06 Posted February 9, 2014 Report Posted February 9, 2014 Did you do a leakdown test 60 pilot is close to what my drag ported alky bike runs Quote
quadgod211 Posted February 9, 2014 Report Posted February 9, 2014 I'll trade ya a set of 35 pwks bored to 36 like new....im looking for 38-39s for my 10 supercub 1 Quote
RadarRacing Posted February 9, 2014 Report Posted February 9, 2014 Sounds like the needles might have been quite lean and the rest sounds like a burndown. I am sure the pull starting couldnt have helped it. Quote
hughmyron Posted February 9, 2014 Author Report Posted February 9, 2014 What needle do you have in the carbs, did you check compression , that sounds lean for a drag ported cub close to sea level , I would check compression that will let you know if you burnt it down Did you do a leakdown test 60 pilot is close to what my drag ported alky bike runs Sounds like the needles might have been quite lean and the rest sounds like a burndown. I am sure the pull starting couldnt have helped it. The needles that come with pwk 39s. What do you guys mean by a burn down? Pulled the plugs yesterday and checked the pistons for any signs of detonation pistons look great and brownish. Can still read the part numbers on em. Quote
J-Madd Posted February 9, 2014 Report Posted February 9, 2014 If you have to run the air screw all the way closed, the pilots are too small. 1 Quote
Coupelx Posted February 9, 2014 Report Posted February 9, 2014 Have no idea then you might get an idea before you burn it down. Quote
hughmyron Posted February 9, 2014 Author Report Posted February 9, 2014 then you might get an idea before you burn it down. How exactly do i go about checking the float level? Quote
sprinklerman Posted February 9, 2014 Report Posted February 9, 2014 Do a search... Instead of expecting people to spoon feed you info that's already been addressed. Plenty of threads on this topic. Sent from a van down by the river Quote
dozer Posted February 9, 2014 Report Posted February 9, 2014 http://bansheehq.com/forums/index.php?showtopic=173414 1 Quote
sleeper06 Posted February 9, 2014 Report Posted February 9, 2014 You stated it had spark , only 2 things left compression and fuel thats why I said compression test, due you test it after u built it to know starting point. Quote
