Trail tech lights
Do you happen to have a model number for these I know that company has a few different versions of their setups. Do these require an external ballast or is each light totally self contained and meant to be run off the stock stator? Bulbs good? I need lights and these should fit the bill just curious about these things first, thanks!
no they use an mr16 bulb. minor upgrade from stock. i run the small mr11 hid lights from them with the ballast built in. they are pretty bright but require a battery and dc conversion to work. been debating switching to led lights and ditching the battery though.
  • 3 weeks later...
The mounts they come with would use the upper shock mount bolt, but you have to remove the stock mounting tabs.  I bought these for my LTR and decided to go a different way.  They are in great shape, have no issues, and come with blue covers
  • 1 month later...
