I am all out of guesses here. My banshee is backfiring when you kick it.
Rebuilt carbs
120/105 comp
Finishing up leak down tester
Slides not in wrong carb
Fatty pipes
Pro design filter
Timing plate ( now set at zero) trying to make sure the advanced timing wasn't causing a problem.
I give up. Though I know 105 is low it still should run. I pulled the pipe on the low cylinder to look at sleeve it looks good.
Any suggestions on what to try next?
  • Replies 50
  • Created
  • Last Reply
Top Posters In This Topic
Check and double check that your slides are sync'd properly and your throttle cable has a nice smooth route to the carb. tops.
You've been playing with the timing so I would pull the stator cover and make sure your timing plate is set correctly and locked down tight (most likely your problem). Also check the pick-up gap between fly wheel and pick-up.
Could also suggest to check your reeds and make sure they are good.
I just pulled my stator cover and verified pickup gap. Right now about .015
The timing plate is still at zero and tight
Installed tors eliminator with new cable and tops
Carbs are roughly synced by sight. Trying to get it started to finish sync with sync tool
reeds?
I looked at them they appeared to be closed and looked good. I will probably order some reed gaskets and take them off to get a better look.
Flywheel key
Flywheel key
^^^This. Flywheel spun.
And you disconnected small black box under left side of gas tank?
Yeah took it off all together. I will check the key when I get a chance. If that's the problem I will kick my own ass for overthinking it
…...Didn't you just get this motor running recently?
Yeah guy had it and I traded for it. Just got it running a while ago. Started acting up so I rebuilt the carbs and while I rebuilt the carbs put on the tors eliminator kit.
