Young Guns Racing Posted January 21, 2014 Report Posted January 21, 2014 I took the clutch basket off and everything is installed correct now. Pin in shift star is in but still having same problem. It shifts out but won't move. Back tires roll if I push it even after I put it in gear. I can feel a little tension when it's in gear while pushing it but they should lock if in gear.Check your drive sprocket, if the nut came off or the sprocket itself has spline or teeth issues then it will not move. If all is well externally, it may be time to split your cases Quote
ginger Posted January 21, 2014 Report Posted January 21, 2014 leave the clutch cover off. put it in gear and try to push it, if the clutch is letting it slip you will be able to tell. should limit out the clutch annd pressure plate deal. Quote
Starwriter Posted January 21, 2014 Report Posted January 21, 2014 Since you don't own a Clymer manual, it's going to take a lot more effort on your part to diagnose the problem. We can only point you in the general direction. From there, you have to figure it out. Something is holding the pressure plate away from the clutch discs. Either you didn't line up the arrow on the pressure plate, or the clutch is adjusted wrong, or the clutch ball is welded. With the pressure plate off, tip the bike to the right. The ball and pushrod should fall out onto the floor. (Warning: Make sure your clutch plates or basket don't hit the floor)If the ball and rod don't hit the floor, try removing them with a small magnet. If they still won't come out, it's time to split the cases. Here' is what it looks like when the ball is welded to both the rod and the adjuster screw. If it's only welded to the pushrod, it may be welded to the inside of the tranny shaft. Quote
Carter32ent Posted January 21, 2014 Author Report Posted January 21, 2014 I took the cover off. The ball is not welded but when I put it in gear and push it it still rolls but not as easy as in neutral Quote
Starwriter Posted January 21, 2014 Report Posted January 21, 2014 For the 14th time, did you line up the fucking arrow? If the balls not welded, then either the pressure plate arrow is not lined up or you don't know how to adjust the clutch. Those are the only possibilities. Quote
Carter32ent Posted January 21, 2014 Author Report Posted January 21, 2014 I'm going to check the arrows now Quote
sheerider11 Posted January 21, 2014 Report Posted January 21, 2014 I'm going to check the arrows nowWtf?! That was said a day ago Quote
Carter32ent Posted January 21, 2014 Author Report Posted January 21, 2014 Everything was in tact. Still same problem. It jerks when I put it in gear. Seems like clutches not grabbing Quote
Starwriter Posted January 21, 2014 Report Posted January 21, 2014 Then YOU need to figure out what's holding the pressure plate away from the discs. It's not rocket science. The springs apply pressure on the pressure plate and it clamps the discs. When you pull the clutch lever, you push the pressure plate away from the discs. Quote
Nieskes Posted January 21, 2014 Report Posted January 21, 2014 Cant fix stupid, hate to say that to ya but......... Quote
sheerider11 Posted January 22, 2014 Report Posted January 22, 2014 Where are you located? You need help. Quote
Starwriter Posted January 22, 2014 Report Posted January 22, 2014 Where are you located? You need help. He has a "mechanic" friend. I'm done. "Had a mechanic come by my garage. I was lucky only need a top end. Also told me I did a good job when I took it apart ha ha." Quote
Young Guns Racing Posted January 22, 2014 Report Posted January 22, 2014 He has a "mechanic" friend. I'm done. "Had a mechanic come by my garage. I was lucky only need a top end. Also told me I did a good job when I took it apart ha ha." FFS... Quote
Young Guns Racing Posted January 22, 2014 Report Posted January 22, 2014 If you were rolling the engine over via the transmission....you needed a top end 209353903 hours ago. Wanna sell the engine? That way you wont have to touch it anymore, you can buy one already running and all you gotta do is kick it. Quote
Carter32ent Posted January 22, 2014 Author Report Posted January 22, 2014 It has a new top and bottom end Quote
