screamingtwin Posted November 9, 2003 Report Posted November 9, 2003 I have a 2001 banshee. When I am riding it both pipes smoke but the right one smokes more. And the right pipe is hot and the left is only warm. Also its is running pretty slow. I put new gas in it and it helped it a little bit but not much. PLEASE I NEED HELP. Quote
bignasty1 Posted November 9, 2003 Report Posted November 9, 2003 sounds like your carbs may be out of sync. try a new set of plugs as well. and just go over the hole bike and check every lil thing while your at it. also it could be a clogged jet but its most likly your carbs being out of sync Quote
screamingtwin Posted November 9, 2003 Author Report Posted November 9, 2003 It was wierd because it was running fine then I stopped riding it for a month then go to ride it then this problem occured. The plugs where two diffrent colors. Is that bad? Quote
boonman Posted November 10, 2003 Report Posted November 10, 2003 The plugs where two diffrent colors. Is that bad? This is VERY bad. It indicates that the cylinders are not runnign alike. Which side is smoking more? Quote
